newbie - SX and OLED display
I have been having a tough time getting the SX to work with the OLED display. So far nothing has worked.
Has anyone had success with this combination? I see a lot of comments with the prop chip but nothing with the sx.
Code sample would help. I can only imagine that is where my issue is.
TIA
TIA
Rick
I do not have a schematic diagram
but I attached the reset line to RA1, RA2 to the RX line and RA# to the TX line.
Paul
' Device Settings
DEVICE········· SX28, OSCXT2, TURBO, STACKX, OPTIONX
FREQ··········· 4_000_000
ID··"SERIN"
' values
RstLine······· ·VAR···· RA.1·················· ' I/O pin for RCTIME
Sout·········· ·VAR···· RA.2··················· ' output to SEETRON 2x16
Sin··VAR·RA.3
LED··var·rc.7
Baud··CON·"OT9600"
tRead··var·byte
' Program
Program start
Start:
·high ·LED
·' reset the device
·high ·RstLine
· ·pause·500
·low·RstLine
·pause·500
·high·RstLine
·pause·2000
·low·LED
·' send a u
·SEROUT Sout, baud, $55·············· ·' send the character
·high ·led
·pause ·500
·low·led
·SERIN Sin, baud, tRead
I'm having a problem with my car. It's not running right. Can you figure out why?
Let me guess, you can't really help me because I haven't given you enough information.
That's the amount of info you're giving people here.
If you want help, then you need to post ALL the information. Schematics, part numbers, code, etc. For example, you say you can't get the OLED to work. What OLED? It's not like there is just one OLED in the world. Is it serial? Parallel? Who made it? The lack of a schematic makes it hard as well. Is the circuit your own design? A Parallax board? Is there a level inverter on the serial output? Are you using a resonator? An oscillator? The built in oscillator?
Don't have a schematic? Then make one. There are about a zillion drawing programs on the market, as well as free circuit design programs like Eagle. You can download it from here:
www.cadsoft.de/
You can also just draw something on a piece of paper and scan it into the computer.
Basically, if you want help, you need to step up and provide enough information for people to help you without playing 20 questions.
PeterM
Also, put an "Sout = 1" at the very start of the init sequence -- this will put a high on the Sout the first time it is made an output, so that OLED doesn't see a false start bit.
I would also explicitly define your pins as inputs/outputs and just use pin = 1 or pin = 0 to set states, rather than HIGH and LOW, e.g.
Is this the *whole* program? It doesn't end, nor does it loop back to the beginning. As it stands, I would think it would crash after the SERIN. Lastly, I would take out the pause 500 after the serout -- you are waiting 500ms for a response -- I would think serin will hang as the response will surely have come before the 500ms is up. Remember that SERIN WILL WAIT for a start bit, then read 8 bits at the given baud rate....
Of course, w/o a schematic, spec sheet on the OLED, etc, it's hard to know if you have already done this, if your baud is correct, if your commands are correct, if indeed the device is open true serial comm., etc.
Just to verify for myself, will the internal pullups work or do you have to have an external pullup.
Shawn Lowe
When all else fails.....procrastinate!
Also, the larger external resistor gives the juice a place to go if for some reason both a slave and the master drive the line in opposite directions (which shouldn't happen, but we all make mistakes -- generally with open true the slave or the master drives the line low, and "releases" the high level (by making the serial pin an input).
Shawn Lowe
