Pbasic without hardware
Ok I was able to download and install the "BASIC Stamp Windows Editor version 2.4.2" thanks
to Franklin. Now what can I do with this without any hardware.
- Stephen
The $50 OEM module is the BS2SX, but you can get a regular BS2 for just $31. Of course in either case you have to be comfortable soldering it together, but they're not that hard.
How can you do this without a stamp connected?
Deus tantum me iudicabit
- Stephen
So I just need to do a "Syntax Check" and this will inform me if the code will compile.
This is quite handy while working on code before actually loading it into a Stamp.
Thanks Stephen and remmi870.
Have a look here and try to pick up a good deal on some hardware at Parallax's E-Bay site http://shop.ebay.com/merchant/pbasic1_W0QQ_nkwZQQ_armrsZ1QQ_fromZQQ_mdoZ
Whit+
I'm with Allanlane5 and the OEMBS2
Instead of soldering in the right Angel male SIP header, Replace it with a female SIP header.
From this female header You can jumper out to a bread board and make many experiments with it.
The female SIP headers can be found on the Parallax store web page along with pretty much all of the needed IC's for the experiments in the StampWorks Manuel.
___Welcome to the club____________$WMc%______________
The Truth is out there············································ BoogerWoods, FL. USA
