Compatibility Check
Kye
Hey guys,
Can I connect this device to the propellers I2C pins (29 and 28) without ill affects?
http://www.sparkfun.com/commerce/product_info.php?products_id=99
Its the ds1307 real time clock.
Or should I put resistors between it and the I2C line?
Nyamekye,
Nyamekye,
If you want to run the DS1307 at 5 V simply put a 1k resistor inline between the DS1307 and the rest of the I2C bus.
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
I'm using the prop proto board btw.
Nyamekye,
· -- Carl, nn5i@arrl.net
