Audio Input and ouput for the propeller
Hey guys,
I can't seem to find any information on this online and I'm having a bit of a problem figuring it out myself.
I want to get the propeller chip to be able to output audio and input audio. My idea is that if I use operational amplfiers to integrate a pwm wave I can then create a nice DAC for sound generation. For audio input I plan to use a comparator with a sample and check circuit which simply generates a voltage using the audio output technique and then·uses the campator to check if the voltage generated is equal to the input, this is then done very fast to sample the input.
Now, addtionally the point of the operational amplfiers is to produce a level shifted signal for the PC audio. The problem is... I can't seem to find good reference material on what the the PC audio line level voltage is and how it swings. Additonally I'm not sure if a the 5V power supply on the prop proto board can power the operational amplfiers.
I'm not really good at using analog circuits. Help would be appreciated.
Thank you,
Oh, at the bottom are some quick sketches of the circuits.
There would be 3 analog output circuits and 1 comparator circuit. The first two analog output circuits would generate stereo audio and third would be used to drive the analog input for the comparator to sample the input signal.
Nyamekye,
Thank you,
Nyamekye,
I think your circuits will cause too much distortion for the singal to be close to the original.
Paul Baker
The idea is that the operational amplfiers integrate (like low pass) the pwm signal to generate a voltage which is then level shifted to the proper level.
Nyamekye,
http://www.ovnilab.com/articles/linelevel.shtml
If you want to get into the analog side of things, there is the all about circuits series (google it), and for op amps, a good reference is the TI publication:
OP AMPS for Everyone and Handbook of Operational Amplifiers, both published by TI. Downloadable as PDF. Best of all the price point can not be beat..FREE!!
Since then, Kye has published some awsome audio stuff in OBEX.
But hopefully the references will be of use to someone.......
And yes, I will go see what he has placed in OBEX. He has a thing for doing interesting/awesome stuff it seems....
Speaking of audio in/out...
Heres a chip for such purpose...
http://www.sparkfun.com/products/9943
AND RAM to make up for the props lack of it,...
23K256 32KB SRAM
http://www.digikey.com/product-detail/en/23K256-I%2FP/23K256-I%2FP-ND/2001112
And an example project using the VS1053 chip, the propeller, ethernet, and the extra RAM.
http://learn.parallax.com/inspiration/thumper
http://forums.parallax.com/showthread.php/153288-VS1053-mSD-to-run-mp3-on-its-own?highlight=vs1053
http://forums.parallax.com/showthread.php/138503
http://forums.parallax.com/showthread.php/127083-2-audio-source-to-1-headset?highlight=vs1053
http://forums.parallax.com/showthread.php/121305-Who-has-some-experience-with-VS10xx-decoder-chips?highlight=vs1053
Harrisonpham.com shows nothing, and all other websites referred don't work.
http://hdpham.com
http://forums.parallax.com/member.php/40649-Harrison.
http://forums.parallax.com/search.php?searchid=1871238
You can find one obex object from the same author.... http://obex.parallax.com/object/222
