IR help
how would i connect and program a radio shack emitter and detector to work as a·ir sensors? I am trying to make an ir sensor using a radio shack emmitter and detector pair, but i wasn't able to get it to work with the ir programs written for the sumo bots and the boe bots. can someone please help me out?
Post Edited (BOB55) : 1/19/2009 9:37:20 PM GMT
Your duplicate post was removed. Please do not cross post. In order for others to know how to help you I would suggest editing your message to elaborate on what exactly you mean. Mentioning what you are trying to connect to and what parts you are referring to would help greatly. You can edit your message using the pencil icon to the top right of your message.
Parallax Engineering
An IR receiver module contains a phototransistor plus LOTS of extra circuitry to filter and integrate a very specific modulated signal, usually on a 38 kHz IR carrier. Typical remote controls and the BoeBot/Scribbler object detectors use this 38 kHz system. It is better-suited for working in real-world conditions where the ambient light level may be very dark or very bright.
Bottom line: the phototransistor sensor you got from the Shack's matched pair is NOT a substitute for a 38kHz IR receiver module. The Shack does carry those, but they cost more.
