AC Voltage monitor
I'm wanting to monitor the AC Voltage from a home outlet and eventually input the data into a PC, but first things first. I'm thinking something like AC voltage in to a bridge, then into a comparator that feeds an LED graph . . .
AC
> comparator ----> Bar Graph
Thanks for your feedback
Daniel Mueth
"Just plug it in and let's see what happens"
AC
Daniel Mueth
You could use one side of the winding for sensing and the other side for +5V regulated power for the circuit.
And heed Mike's cautions -- you absolutely must isolate from the line, for safety.· Any transformer except an autotransformer will do that·perfectly.
· -- Carl, nn5i@arrl.net
A couple of suggestions...
Have a look at this circuit:
www.edn.com/article/CA6455602.html
The schematic is attached. Basically this uses an opto-isolator feeding an RC circuit on the output. The result is a pulse-width that is proportional to the AC voltage. Perhaps you can measure the output with a Propeller timer-counter. The circuit is completely isolated from the line.
Fairchild semiconductor has the MID400 AC line monitor chip. It comes in an 8-pin DIP package too.
www.fairchildsemi.com/pf/MI/MID400.html
This part doesn't have an analog output, it is a logic output; but you can set the input threshold where the output is switched.
Enjoy... David
