Array Handling Difficulties — Parallax Forums
william chanwilliam chan Posts: 1,326
edited 2009-01-19 12:52 in Propeller 1
Help!
I tried doing
VAR
long mydata[noparse][[/noparse]20]
index := 1
third := 3
mydata[noparse][[/noparse]index].byte[noparse][[/noparse]third] := 100
but the compiler keeps complaining "variable needs a parameter"....
What gives?
www.fd.com.my
www.mercedes.com.my
  • Erik FriesenErik Friesen Posts: 1,071
    edited 2009-01-19 03:33
    You will have to do it this way.
    mydata.byte[noparse][[/noparse](index*4)+third]
  • william chanwilliam chan Posts: 1,326
    edited 2009-01-19 03:57
    I thought the most logical and clean way would be my example code.
    This is most unusual.
    Thanks for your help.
    www.fd.com.my
    www.mercedes.com.my
    edited 2009-01-19 04:25
    William,
    I can't disagree. A subscripted variable should still produce a typed "lvalue" on the compile stack that's subject to further modification. It's probably not a bug in the compiler, but more likely just an oversight.
    I have smacked my head into this one too. I think I have tried every possible combination. I'd agree with phil.
