servo going in circles
so i have this not so contiuous rotation servo that started to continously rotate, nothing get hot or anything, i was messing with the wii nunchuck on the prop, is this a broken servo now, or can i still get precision out of it
- Stephen
if you can control the servo within its range of motion then the potentiometer is still good.
if you can't then you may well have damaged the pickup (spring loaded fingers) that feeds the position back to the servo's internal controller chip.
basic law of buying servos is buy one more than you need and use one of them for all your initial experiments.
