Building a DATA table in SXB
I am trying to build a data table with a series of 4 digit numbers. I would like to retrieve each entry·as a word with two digits in each byte.· However, when I enter the data in the form of:
WDATA 0175.0249,etc the compiler is giving me:
0075 0001 0049 0002 etc.· I have tried entering it as 75,01,49,02 etc and I have tried $0175,$0249 etc
Each time the compiler gives me back two words with leading 0.· What is the secret of building this table?
Jim
Jim
So if the "Word" data I wanted to write (say it was BCD numbers) is:
$1776
I would expect to see two 12 bit instructions in the compiler output:
DW $076 ' upper 4 bits of instruction = 0, lowest 8 bits are the low byte of my "Word" data
DW $017 ' upper 4 bits of instruction = 0, lowest 8 bits are the high byte of my "Word" data
In assembly and in SX/B 2.x there are strategies for using the whole 12 bits in cases where 12 bits is enough but 8 bits are too few. Or if you want to really "compact" Data by stuffing three 16 bit words into four data instructions (a savings of two instructions).
If you post your code that would help alot.
It sounds to me like you want:
DATA 75,01,49,02 ' Note this is NOT WDATA
Bean.
·The next time you need a hero don't look up in the sky...Look in the mirror.
Jim
