SX28 hangs while trying to execute RX_BYTE function??
would anyone know any reason that would cause an SX28 to lock up when running this function?
usage : cmd = RX_BYTE
I have 2 SX's talking to each other. One is the Display chip which shows a menu on an LCD and it also saves to an eeprom. The other is the data chip which controls user input. Everything works perfect when sending data from the Data chip to the Display chip, but when the Data chip sends the command to the Display chip to load information from the eeprom, it processes everything correctly but the Data chip does not retrieve the data. Sometimes it will retrieve it, but it takes over 30 seconds. All help will greatly be appreciated!!!
FUNC RX_BYTE SERIN RX, Baud, temp1 RETURN temp1 ENDFUNC
SERIN never receives data
Baud is wrong (although that usually leads to wrong data, not blocking)
RX is an output rather than input
temp1 is an alias for a __PARAMx systemvariable used by SERIN
Best advice: post the complete code as attachement
if you can't solve it.
regards peter
