Upload or debug existing program with basic stamp 1
Is there a way to either upload what is on a stamp1 project board·or run it in a debug window without redownloading it?· I know it works and want to confirm the code.
THANKS!
THANKS!
Long answer;: Well, you *can* read the eeprom by loading a short program that will dump all the data in the eeprom. However, you will lose the area that the new program is loaded into, and all you will have is the interpreter bytes,not basic code. So, practically speaking, the answer is still no.
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
HTH
Jonathan
a) Have the programming cable attached, then
b) Have the Stamp Editor open and a debug window open then
c) Power up the Stamp
You should see the debugs if they exsist in the program. If not, then there aren't any debugs in the program (ie the program loaded is not the one you think it is), or possibly the programming connection isn't working.Can you identify the Stamp with the identify option? If not, the problem is likely in the cable or comm port.
Jonathan
EDIT: Did you check the battery·if you are using one?
Sorry. [noparse]:([/noparse]
- Stephen
- Stephen
