Propeller/lcd monitor problems — Parallax Forums
Computer Geek 101Computer Geek 101 Posts: 179
edited 2009-01-20 12:39 in Propeller 1
I have a few job display boards where I work.· One display that has been in action for about 10 months is now started to act funny.· If I hook it up to my laptop it will work all day.· If I connect it to the job display box it will work for a while then the screen goes black.· I replaced the prop with a new one and it still does it.· Anyone ever have any similar problems with a prop/lcd monitor system?· Is it just the monitor just going bad?· Thanks for any ideas.
    edited 2009-01-16 21:11
    Computer Geek 101 said...
    One display that has been in action for about 10 months is now started to act funny. If I hook it up to my laptop it will work all day. If I connect it to the job display box it will work for a while then the screen goes black
    1.Check the Xtal freq or just try another Xtal.
    2. Could be a bad voltage regulator. Check the voltages on the prop chip before it goes dead and then after.
    Aka: CosmicBob
  • LeonLeon Posts: 7,620
    edited 2009-01-16 21:19
    Another possibility is a piece of new equipment that is putting a glitch into the system via the mains supply.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • RaymanRayman Posts: 16,231
    edited 2009-01-16 21:25
    Sound like a power supply problem... Maybe an overheating voltage regulator?
  • Computer Geek 101Computer Geek 101 Posts: 179
    Thanks guys. Ill check them out today.
