What Is The Lifespan Of A Servo?
John Burrow
I am using 10 Pico Servos on my model railroad. These will spend up to 6 hours a day powered up, but not necessarily moving.
The movement is 'occasional' (maybe 10 times per hour). I use only a small percentage of the rotation (pulse 800 to 2000) approx. The servo has much more power than is needed to just to move a semaphore signal. I had planned to send pulses only when movement is required; pulsing is not required to hold position
But now I've run out of pins on my BS2P, so I'm considering using a Servo Controller (which I already have).·My understanding is that this will continually pulse the servos to hold position. If this is correct, so am I going to burn out or cause early failure of the servo due to the 6 hours a day usage? An alternative is to go to a BS2P40,·which will give me the extra pins, where I can pulse only when movement is required.
John Burrow
San Diego
John Burrow
San Diego
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
You can easily verify this by comparing the current draw when not pulsed, pulsed, not moving, and moving. I'd expect the first three to have very similar current draw.
Jason
