Clock the Prop from ENC28J60? — Parallax Forums
RaymanRayman Posts: 15,406
edited 2009-01-16 05:56 in Propeller 1
I'm thinking about building a circuit with an ENC28J60 ethernet controller...
Just noticed that it puts out a 6.25 MHz clock source by default...
This looks perfect for driving the Prop at 100 MHz!
I've seen that people have use the Prop with 5 MHz crystal to clock ENC28J60,
but this looks better to me.
Anybody see a problem with this?
    edited 2009-01-15 19:51
    The chip provides a CLKOUT pin for this purpose, so it ought to work.
    edited 2009-01-16 05:52
    will the chip be able to handle being overclocked? Anyone test how well it works?
    Read the datasheet!
    There's a graph showing the tested maximum system clock frequency vs. ambient temperature and supply voltage.
