Voltage Doubler
I have been trying to make a simple voltage doubler for a·little side·project I am working on, but I can't get it to work right.
Here are two of them that I have tried with no success.
http://www.facstaff.bucknell.edu/mastascu/eLessonsHTML/UsefulCircuits/VoltageDoubler.htm
http://www.creative-science.org.uk/multipliers.html
It looks simple enough, but it just does not like me. Where the the voltage is supposed to be double it was reading almost half the supply voltage. Any ideas would be greatly appreciated.
James Dougherty
Ariel Productions
http://www.arielproductions.com/
James Dougherty
Ariel Productions
By the way, thank you for your help.
[noparse][[/noparse]EDIT]
I know they make the rectifiers to go from AC to DC, but what do you use to go from AC to DC? Is there any easier way to amplify (double) the voltage?
James Dougherty
Ariel Productions
Post Edited (JamesDougherty) : 1/15/2009 2:17:47 PM GMT
Ron
The input to C1 must be a 50% square wave.
The output is (Vdd*2)-(2*diode drop), so for 5V you will probably get about 8.5V or so.
Bean.
·The next time you need a hero don't look up in the sky...Look in the mirror.
James Dougherty
Ariel Productions
Bean.
Thank you so much for your help!
James Dougherty
Ariel Productions
If your pin is only good for 20mA, then trying to suck more than 10mA out of this will lead to disappointment, and maybe smoke. This is actually quite an unpleasant thing to do to an output pin. It'll be seeing damn close to a dead short at the start of each cycle. Some careful messing with the square wave frequency and capacitor sizes may be called for. I'd suggest that the capacitor at the left be 1/10 the size of the one to the right, as a first guess.
Also, schottky diodes are good in this application - lower forward voltage drop, lower capacitance, better efficiency all round. BAT54S if you're in surface mount territory, gets you the 2 diodes in series that you want.
Steve
Rick
James Dougherty
Ariel Productions
Funny you should show up now, I just put one of micro boards in my bag so I have something to play with at Cabin Fever this weekend. Have you tried it with the Linux IDE?
Ron
They _all_ need AC. That's the way they work. If you just want something that turns 5V into 10V, you need something like http://search.ebay.co.uk/360121702406
5V in, 10V out. They cost rather more than a few Cs and diodes, though. (There's AC stuff going on inside, but it's hidden from you, and you pay for that privilege)
If you can generate a square wave, then that _is_ your AC, and you can feed that into your doubler. When you stop generating your square wave, you'll stop getting twice the voltage. Since you can easily generate a square wave under interrupts, there's no real need to stop...
What do you need this 10V for, anyway? How much current? How stable? How cheap? More information in the question will get you better answers.
Steve
Post Edited (SteveW) : 1/15/2009 6:04:53 PM GMT
Post Edited (Phil Pilgrim (PhiPi)) : 1/15/2009 6:51:57 PM GMT
Well, sort of. But not when the first component in the circuit (all of them) is a coupling capacitor [noparse]:)[/noparse]
I still think we need more information about what this 10(ish) volts is intended for - I smell a potential calamity.
Edit: Not really calamity. Much more likely is a drooping doubler, delivering V-2diodes, rather than V*2. Forcing non-trivial power through doublers (and above) takes beefier drivers than an SX pin... (I usually hang them off the driven node of switchers, which also causes trouble if the switch mode controller chip is a bit fussy about overcurrent)
Steve
Post Edited (SteveW) : 1/15/2009 6:55:29 PM GMT
I like a challenge...
Best I can come up with, though, is a LED/photocell (or photodiode, if you need _pitiful_ currents.)
No moving parts or nodes, though, and galvanic isolation for free... Bill of materials isn't dreadful, but it's going to take some space, and efficiency will be woeful.
Steve
I'd probably be using a UV LED for efficiency, so it's even worse than that [noparse]:)[/noparse]
Still, my 'scope (1GHz) and spectrum analyser (21GHz) are both convinced that 400THz is DC, and that's good enough for me...
Edit: Also, remember when 400THz was an unthinkably high frequency? Just seems like a matter of time before we're blurring the lines.
Steve
Post Edited (SteveW) : 1/15/2009 11:05:27 PM GMT
Remember, just because the color of the light creates a wavelength equivalent to 400 THz, doesn't mean all the waves are hitting the "high" and "low" ("on" and "off") at the same time. It's a bunch of incoherent waves, not something in unison like a radio signal.
Maybe a ruby laser striking a stream of electrons in a cathode ray tube could induce that kind of 400 THz oscillation in the electrons it strikes (i.e. if you created a free-electron laser, itself pumped with another, conventional laser), but then I'm pretty sure it would all be re-emitted as red light before the electrons left the tube.
Edit: Although I have often wondered, if you could make such a setup, and get rid of enough parasitic capacitance, whether the wire itself would throw off red light like a radio antenna for light, if only for a fraction of an inch as the electrons enter the wire. Alas, at such high frequencies, any capacitance at all would cancel out the effect.
Post Edited (Dennis Ferron) : 1/15/2009 11:30:43 PM GMT
That's really not true. When the input to C1 is grounded, it charges (via D1) to 5V - Vfwd(diode). When the input is subsequently raised to 5V, it's still carrying that charge, so its high side has a voltage relative to Vss of 10V - Vfwd, charging C2 (via D2) with 10V - 2Vfwd. When the input to C1 returns to ground, it again charges to 5V - Vfwd, and the process continues.
If a negative voltage were required for switched capacitor voltage converters, chips like the MAX232 or ICL7660, for example, would never be able to operate without a negative supply voltage.
Post Edited (Phil Pilgrim (PhiPi)) : 1/16/2009 8:45:10 AM GMT
I believe you are wrong, and that a square wave between 0V and 5V will drive that circuit perfectly.
Look, there's a capacitor in the front of the circuit. Feed it anything you like (within reason), the capacitor will remove the DC, and pass the AC, it's what they do. 0V,5V, or 20V, 25V, or -2.5V,+2.5V, all fine.
Also, for what its worth, it works in practice, too. I have millions of these things out in the field, running as doublers, triplers and inverters. It's a standard way of generating those irritating low current feeds that you find yourself needing, and comes very nearly for free when you've got a handy switch mode PSU generating a high current rail.
Steve
