Crash Sensor
Hi all,
I've been working on a project for the last, ooh, 3 months or so to develop a padded bag (the sort used in martial arts and sports) that will accurately record the force of a blow struck to it. I'm using the Basic Stamp to process the whole thing, and so far, after several revisions of the sensor mounted in the bag, am still unsuccessful.
My first plan was to use a dual axis accelerometer, which didn't work. The impacts were much greater than the sensor could read. Same story with the Tri-axis. Then I put in the Piezo Film sensor, and put a small weight on the top of it (so the impact would make it wobble, and thus show impact) but, lo and behold, nadda.
So I thought I'd open it up on here. What ideas to people have for a sensor that could measure a hit for me? I'm not just looking to sense the hit, I want to know exactly how hard the hit was. The sensor is mounted in the center of the bag, which is in turn held vertically and very still by a person. A target has been placed on the bag to show the exact location of the sensor (for maximum accuracy of the reading) and a cable runs from the back of the bag to the controller box which is stored on the holder's belt.
So does anyone have any good ideas on how I can build this sensor? I imagine it'd be something similar to what is used in car crash test dummies... Can't seem to find those sensors being sold to the general consumer though...
Thanks in advance for your help, guys!
http://forums.parallax.com/showthread.php?p=771713
Just for extra info...
- Stephen
In the 'TakeHit' subroutine, it needs to check for a button press so that it can go back to the score recording screen. (Just so you know)
Using acceleration sensors would be optimal in this instance, but the accelerometers provided by Parallax don't seem to be good enough for it. The G's imparted by a skilled kick upon the bag far exceed 3Gs...
So to cope with that, I have mounted a small box inside the bag, right where it will be hit. Inside the box is a small PCB with one of the Piezo Film Flex Sensors sticking vertically out of it. At the top of the sensor is a small weight, so when the bag moves backwards suddenly, the piezo sensor is forced to bend forward (like someone's head in a car crash) and I am measuring the bend...
Are you talking about these? http://www.parallax.com/Store/Sensors/PressureFlexRPM/tabid/177/CategoryID/52/List/0/Level/a/ProductID/384/Default.aspx?SortField=ProductName%2cProductName
Have you thought of something like this?
http://www.parallax.com/Store/Sensors/PressureFlexRPM/tabid/177/CategoryID/52/List/0/Level/a/ProductID/499/Default.aspx?SortField=ProductName%2cProductName
Whit+
http://www.parallax.com/Store/Sensors/PressureFlexRPM/tabid/177/CategoryID/52/List/0/Level/a/ProductID/89/Default.aspx?SortField=ProductName,ProductName
The load sensor only detects up to 10lbs. A good sidekick can generate up to 800lbs of force, unfortunately...
The company that makes the iLoad makes one that can measure up to 200 lbs, but that is still not enough.
There must be some way to do this though.
Whit+
Grargh! I'm sure with our combined minds we can think of something.....
Why not put a Smart Cinderella slipper on the kicker? Put an accelerometer in the glove or slipper....it should be able to detect acceleration/deceleration and you'd be able to determine force from that?!
How about a couple of strain-type gauges? I would've said put one from the floor to the bottom of the bag, but the person holding the bag would defeat this.
How rigid is the bag from it's topcenter down through to the bottom center?
You could put a plate in the center of the bag....when the target zone is hit, another plate is pushed towards this sensing plate and would create a capacitance.
You'd have to have power running through this and I'm not sure how much power you'd have to put through to be able to measure.
You could also use a couple of coils....like an isolation transformer....you hit the target and it pushes one coil towards the other and the electromagnetics induce in each other.
Or a coil and magnet setup....one induces a voltage in the other....
Cheers
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
The sensor has a small "sense" area....you need to couple this sense area to your bag surface.
People don't want to kick a hard bag, so the bag is cushioned and padded to absorb the hit and protect the foot.
I'm sure you might be able to leave the accelerometer in there and do some math to see that the "little" sensor movement relates to an impact of "X".
Of course, your only way of testing this is to swing a known weight from a known height and calculate it's force on impact. Then do a look up table.
Would the size of the impact object change the table? A big foot hitting at X force would hit more cushion and therefore not translate in to Y force....but a small foot hitting at the same X force would impact less cushion (think force per sq inch) but would be sensed as a Y+Z or a 2Y??
Unless you move the sensor up to the impact/contact zone, you'll constantly have this issue.
It's probably easier to put the sensor in to a glove/slipper and you could measure for the peak force....granted, you have to play with wires....
Keep us posted!
<FONT>Steve
http://www.instructables.com/id/Knit_touchpad/
or conductive foam
http://forums.parallax.com/showthread.php?p=764574
Post Edited (john_s) : 1/24/2009 11:44:05 PM GMT
