??PWM
How does one calculate or determine the optimal PWM Frequency.
What factors influence to help to find the optimal frequency and do they exist.
Siri
Siri
Resistive loads can usually be any frequency. The power lost here is simply in the switching transistion(usually mosfets).
beingg totally close to totally open and all ranges in between.
The Solenoid coil is 11 Ohms and rated at 5V d.c. Pressure from 1-50 psi.
Siri
