How to read from Keyboard?
I·trying to so a remote control onto my sumobot which uses basic stamp 2.
Now what is my problem is i can not read from keyboard.
I·going to use "wasd" to control my sumobot while having the cable connect to sumobot. So now, can i read from keyboard when i press "w" then i do checking?
If you know the command, pls reply me as soon as possible because·i really need to·solve this problem fast. thanks
http://forums.parallax.com/showthread.php?p=755918
i edit the program from your program
now i can RC---remote control my sumobot using "wasd" key already.
thanks
my program is
' {$STAMP BS2}
' {$PBASIC 2.5}
'The purpose of this program is To use "wasd" key To control sumobot direction, promped
'by the debug window. Note that you don't need to redownload the program everytime if
'it's already on the BS2. You just need to open a debug window on the correct COM port.
[noparse][[/noparse] I/O Definitions ]
LMotor PIN 13 ' left servo motor
RMotor PIN 12 ' right servo motor
out PIN 0
[noparse][[/noparse] Constants ]
LFwdFast CON 900 ' left motor fwd; fast
LFwdSlow CON 800 ' left motor fwd; slow
LStop CON 750 ' left motor stop
LRevSlow CON 700 ' left motor rev; slow
LRevFast CON 500 ' left motor rev; fast
RFwdFast CON 500 ' right motor fwd; fast
RFwdSlow CON 700 ' right motor fwd; slow
RStop CON 750 ' right motor stop
RRevSlow CON 800 ' right motor rev; slow
RRevFast CON 1000 ' right motor rev; fast
[noparse][[/noparse] Variables ]
letter VAR Byte
done VAR Byte
[noparse][[/noparse] Initialization ]
Reset:
LOW LMotor ' initialize motor outputs
LOW RMotor
PAUSE 2000 ' time to disconnect cable
[noparse][[/noparse] Program Code ]
DEBUG "Use wasd key to control the sumobot", CR, "w to move forward",CR, "a to turn left", CR,
"s to move reverse", CR, "d to turn right", CR, CR
DO
GOSUB _SendData
LOOP
'Send one char at a time
_SendData:
done = 0
DEBUG CR, "You >> "
DO WHILE done = 0
DEBUGIN STR letter \1
SEROUT out, 84, [noparse][[/noparse]letter, CR]
IF(letter = 119)THEN 'if w is pressed'
PULSOUT LMotor, LFwdFast
PULSOUT RMotor, RFwdFast
PAUSE 20
done = 1
ENDIF
IF(letter = 97)THEN 'if a is pressed'
PULSOUT LMotor, LStop
PAUSE 20
done = 1
ENDIF
IF(letter = 115)THEN 'if s is pressed'
PULSOUT LMotor, LRevFast
PULSOUT RMotor, RRevFast
PAUSE 20
done = 1
ENDIF
IF(letter = 100)THEN 'if s is pressed'
PULSOUT RMotor, RStop
PAUSE 20
done = 1
ENDIF
LOOP
RETURN
I have this Condition
After i press "w" once (moving foward) until i press other key.
Which mean how do i edit the program above to have a "continuous moving" until i press other command Key.
If there is a way, pls send me tonite?
Because my Supervisor today come out with this requirement and tommorow is my presentation........
really
HELP ME
