Smoke Sensor
I'm looking for a smoke sensor, to monitor an outdoor wood burning(OWB) boiler,
so I can have more data and legal amunition, when I sue my neighbor.
This thing is about 30 feet from the corner of my house and at times my back yard
is virtually white out with smoke.
I'd like to monitor and record particulate levels.· I think the particulates are the most
dangerous, or most un-healthy, for a person.· I'm not sure about this, yet.
I've only begun my research and perhaps CO and CO2 levels are also·of concern.·
I actually don't know for sure the composition and characteristics of smoke
in general, or what sensors might be available.
I'll add this to my weather station with a real time clock an make a data logger.
I have found the Futurlec sensors, but that's it so far.· Any links, ideas, suggestions, hints,
notions, concepts, thoughts, principles, moans, groans, and grunts---would be appreciated.
it comes up with mostly scientific and automotive instruments.
-dan
Another sensor that you might want to consider is an infrared thermometer to measure the temperature of the boiler so that you can make the connection between the high temperature with the measured air pollution.
Parallax Engineering
Paul Baker
http://www.standardics.nxp.com/support/design/microcontrollers/smoke.detector/pdf/documentation.pdf
Robert
Perhaps temp/Rh....
Anyhow, SRLM has a good idea. We use one of these for field projects and I think it was called an extinction meter.
Shine a light, of a known power, across to a reflector and back. The lower the return signal, the higher the scattering...the higher the particulate level.
You could also measure backscatter....put a transmitter and a receiver beside each other (pointing in the same direction of course, then turn it on. The more light you get in to your receiver means there's a lot of backscatter (this one works best with non visible spectrum, although you could have a sensor that adjusts for ambient light).
There's lots of fun ways to put together some information.
Is your neighbors stack at the proper height?
Have you talked to them at all? Or can you not get the words out amid all the hacking and coughing! [noparse];)[/noparse]
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
Whether using backscatter or transmissivity, you will need to modulate the light, and detect the modulating signal at the receiver -- that's the only really effective method to distinguish the return signal from ambient light.· One excellent (and inexspensive) method is to modulate with, say, a 700 Hz sinusoid (avoiding harmonics of the ubiquitous·50- or 60-Hz power-line hum), and then filter the detected signal with something like an LMF100 switched-capacitor filter.
Brainstorming now, about things I actually know nothing about, I speculate that if you did this with several colors of light you might also get some information about the composition of the smoke.
· -- Carl, nn5i@arrl.net
