Ds1302 readburst & gosub/return
 hmlittle59
hmlittle59
                    Hello All
I've been using this DS1302 Demo code(Stripped down to fit my needs) for over a year now and it works. I'm only using the 24hr format. But now I want to only read the values "ReadRTCBurst", and do a comparison with them. But after 3 days of trying to find a bug it appears to be with the way I'm trying to get the time values. The one on the wall works great, no problem, but this expanded version of my code showed up when I went 3 deep with my GOSUB/RETURN and needed to get the time values and there appears to be NO RETURN values on the STACK. What am I doing wrong in the way I'm reading the values from the DS1302? The DEBUG "CAT", allowed me to track it down to this "GOSUB" routine. With the "CAT" code in place it RETURNed to the Main Menu, without it and "ReadRTCBurst" in place the BS2e crashed every time.
1) I'm 3 deep with GOSUB and this routine CRASHES the STACK(RE-Boots)
2) Did I leave out some COMMAMDs when doing this READ?
3) Why does this routine work as is but not with (GOSUB ReadRTCBurst)
4) I must have forgotten to turn something on...What I don't know?????
thanks for any help
[noparse][[/noparse]code]
I HAVE LEARN SO MUCH...BUT STILL KNOW SO LITTLE!!!
hmlittle59
thanks for any help
ReadRTCBurst:                    ' Read all time-keeping registers in one burst
                       '  DEBUG " CAT":PAUSE 1000
                       '  RETURN
  HIGH RTCCS
  SHIFTOUT DTA, Clk, LSBFIRST, [noparse][[/noparse]%1\1,BrstReg\5,%10\2]
  SHIFTIN  DTA, Clk, LSBPRE, [noparse][[/noparse]Seconds,Minutes,Hours,Date,Month,Day,Year]
  LOW RTCCS
RETURN
'                   'Print short date format on LCD screen...mm/dd/yy
PrintDate:
  GOSUB ReadRTCBurst
  SEROUT LCDScreen, Baud, [noparse][[/noparse]LcdLine2,HEX2 Month, "/", HEX2 Date, "/", HEX2 Year ]
                      'Print 24-hour time format on LCD screen...hh/mm
PrintTime:
  SEROUT LCDScreen, Baud, [noparse][[/noparse]LcdLine2+11,HEX2 hours, ":", HEX2 minutes] 'Display Hrs/Mins
'    ------------------    Print Abbreviated Day of week      ----------------
PrintDay:
   SEROUT LCDscreen, Baud, [noparse][[/noparse]LcdLine1+13] ' LCD Home Position + Off set
   LOOKUP (day - 1), [noparse][[/noparse]Sun, Mon, Tue, Wed, Thu, Fri, Sat], work
   DO                                    ' Display Day Abbreviation
     READ work, idx                      ' Read Each Character Into idx
      IF (idx = 0) THEN exit_PD          ' If 0 then done with day
      SEROUT LCDscreen, Baud, [noparse][[/noparse]idx]      ' Send Character To LCD Display
      work = work + 1                    ' Increment Address
   LOOP                                  ' Next Character, If 0 Then Done
exit_PD:
RETURN                                   ' Back to call routine
hmlittle59
Just read the help file and did an exact count and I'm over the limit. DAG.
Back to the DRAWING Board...
hmlittle59
