Servo Power Source
I am planning on doing some work with servos and really don't want to use a battery pack to power them.
I have a benchtop 25 Amp 12 Volt Supply that I would like to feed into a 5v power regulator. I just don't want to guess at the parts , can a standard 7805 handle a Servo?
Eric
Eric
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
It involves adding a PNP transistor and a series resistor to the input of the 7805. I've never used this circuit before, but it looks like a valid solution to the problem at hand.
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
