INCLUDE path?
My Spin files are a mess. I have different versions of the same thing in dozens of different project directories. I know the Spin IDE does not allow paths to be included in the OBJ file name but is there some other way of doing this?
I'm sure there were some Spin tools like PreSpin etc that were created but I don't know if they are up to date.
What I would love to do is to have a central repository of all my Spin objects and those from the OBEX, even if I had to lump them together in the one folder. That way I only edit and maintain the master with a backup of the edit in a backup folder.
*Peter*
*Peter*
very easy to do.
Every file that you put into the same subfolder as the file "propeller.exe" (usually the folder-name is "Propeller Tool v1.2"
files from objects of this folder are shown as BLUE subobjects when you compile them. This is indicating object from the "main"-propeller-folder = standard-object
Files in the folder "...Propeller Tool v1.2\Examples\Library" are found too when compiling.
And addiionally this offers the oportunity to browse these files with the propeller-tool.
best regards
Stefan
Post Edited (StefanL38) : 1/13/2009 2:54:09 PM GMT
Any ideas anyone?
*Peter*
Couple ideas..
1. Install Propeller Tool on your D (other drive) to get it away from Windows.
2. BST (Brad's Spin Tool) allow multiple search paths.
BST is certainly stable enough for serious spin work. I've been using it for a couple months.
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Got an SD card connected? - PropDOS
