BOEBOT Parallax USB to Serial Adapter cannot connect
Hello all.
I am in a bit of a pinch here. I am trying to get my Mac to talk to my BoeBot and am having no luck. I need this to work for class!
I am using an Intel MacBook Pro running OSX 10.5.5.
I am using the Parallax USB to Serial Adaptor running the drivers found on the FTDI site found here: http://www.ftdichip.com/FTDrivers.htm
I am using the program MacBS2 to try to communicate with the BoeBot. The program is found here http://www.parallax.com/tabid/441/Default.aspx
I have followed all instructions that go along with these various components, but when I try to "Identify" the BASIC Stamp, I get the message "No BASIC Stamp detected. Check connections and port selection" from the MacBS2 program.
The only thing that I am confused about and may have done wrong/not done at all is to configure the port for this application. I do not know how to do this.
Yes, batteries are installed properly, BOEBOT has been tested with a PC and works, all cable connections are being made, and the robot is turned on
Any ideas how to remedy this?
Thanks.
Thanks.
When you tested the BoeBot with a PC, were you using the USB to Serial Adapter? Are you using the same cables you used with the PC?
I'd check the batteries again or use an AC adapter, check the cables again, reinstall a fresh copy of the drivers from FTDI and MacBS2 downloaded from Murat's website.
The batteries in the Bot are brand new and power up the Bot fine.
And after that, It will not connect to the computer.
Is this what happened to you?
Or do you have a Homework Board? (Technically a Homework Board BOE-BOT is called a HOBO-BOT [noparse][[/noparse]HOmework BOard - roBOT)
You can ask Parallax tech support about the problem. Just send them an email.
Send it to support@parallax.com. Happy Camping!
Post Edited (Ezsynn) : 1/22/2009 5:54:18 AM GMT
The first thing you'll have to do is check if you have any current drivers installed. You can check this in /System/Library/Extensions/ and the file name will be FTDIUSBSerialDriver.kext. If there is currently a driver there, you'll have to remove it and restart before installing a new driver.
The Parallax USB to serial adapter uses the FT232R chip from FTDI. You can download the driver for this here.
Scroll down until you find your version of Mac OS. There are drivers for Intel based versions of Mac OS X and for Mac OS X, so be sure to select the correct operating system. Also, make sure the FT232R chip is supported and download the driver.
Hope this helps!
Jessica
Jessica Uelmen
Education Department
