Rechargable Batteries
Invent-O-Doc
I have a portable project that needs about 6Volts. I note that the cases I want to use require (PAC-TEC) require a very large order to get them with a 4xAA door and housing, but the default 9V battery housing will leave me with not enough longevity.
If I got a Lithium or NiMH battery and glued it into a case. How would I hook it up so that it can be recharged when the unit is plugged into an external DC source such as a wall-wart?
Thomas Talbot, MD
Gunpowder, MD, USA
Thomas Talbot, MD
Gunpowder, MD, USA
If you want a charging circuit, then do a search online. Here are two that I found:
http://www.coolcircuit.com/circuit/charger1/standalone_nimh_nicd_charger.html
http://www.angelfire.com/electronic/hayles/charge1.html
Some more information might help get a better response.
My question is: Is there a simple way to do the charging by plugging some DC into my device, or if that would be too complicated, would it be easier to hack a battery charger so I can charge the batteries without removing then from my project case?
I have seen some schematics online, only some appear practical. The best that I found was based upon two LM393s and a thermistor. I'm beginning to think that it might be better to use an R/C universal battery charger.
At this point, I'm mainly wondering what other people who have made projects that rely on a rechargeable battery have done.
Thanks!
Thomas Talbot, MD
Gunpowder, MD, USA
- Rick
Not sure of the size of the case you are using, but check into Polycase. (polycase.com)
~~ dRu ~~
The parts add up to $3-$3.50 I think.
The simplest charger you will find is going to be down the RC charger line. If you charge more than that you will need some sort of charge detection circuitry.
2AA's at 2500mah = 7500 mwh 1 - 9v at 170mah = 1530 mwh. No comparison in rechargeables.
