I'm Up and Running!
Well, I'm up and running on my prop demo board. I made the built in LEDs flash, and I made them go in sequence like the demo program. I got two cogs working on two LEDs. After learning the !outa[noparse]/noparse command, I thought "Could I do PWM with this?" So I threw on a servo and made it waggle! Now I have to make it waggle to an input. I made my own servo methods, but OBEX probably has some. My code is attached, the first is when I didn't do comments, the second is when I actually did comments because I would get yelled at if I didn't.
What do you think of the Arduino now?
Heh.
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Got an SD card connected? - PropDOS
