QTI Line Follower? — Parallax Forums
QTI Line Follower?
IzzyIzzy Posts: 24
edited 2009-01-10 14:23 in Robotics
hi! well i have some questions about the QTI Line Follower
it's possible to build it with the "HomeWork" controller card
if is possible how i must do it? Because i don't know where I must connect the servomotors cables =S
Thanks, and sorry for my english [noparse]:)[/noparse]
  • GWJaxGWJax Posts: 267
    edited 2009-01-10 03:45
    Izzy refer to the Roboticsv2_2.pdf in chapter 2 starting on page 63. I know this is for the Boe-Bot but it will show you how to attach the servos up to the HomeWork Board. you can download this PDF from the download section or just search for the Boe-Bot and scroll down and you'll see it there as well. Hope this helps you out.
    Jax
    Izzy said...
    If a robot has a screw then it must be romoved and hacked into..
  • IzzyIzzy Posts: 24
    GWJax said...
    Jax
    Thanks Jax, that helped me a lot.
