Need to use the Parallax Ultrasonic Sensor ( Ping ) with Propeller
it seems that the Parallax Ultrasonic Sensor
communication PIN voltage is 5 and the
Propeller communications PINs have 3.3V
If I am right, what hardware I need to add to the Propeller
pines to use the Parallax Ultrasonic Sensor.
Thanks, Mark
Thanks, Mark
It does, and not surprisingly, what it asks for is simply a 1K resistor in series on the I/O line between the Ping))) and the Propeller. In general that's how you connect a 5V sensor to a 3.3V Propeller I/O pin.
Are you sure I need only a 1K resistor ?
Please remember that is communication not power supply.
And, do you know if I need to add an only 1K resistor for the other
sensors sold by Parallax to use them with the Propeller ?
I don't understand why Parallax doesn't add a simple 1K resistor
to Propeller microcontroller in order to use all sensors with the Propeller.
Thanks , Jose
Remeber, when the propeller has a pin set to input mode the current draw into it is low, very low. Techinccally its possible to connect a much higher voltage than the pin can handle as long as the current stays very low.
I've sampled 24VDC lines with a BASIC Stamps I/O Pins. If the propeller uses the same kind of circuity the resitor is only needed as a precaution. I would use the resistor however.
Nyamekye,
Basic Stamps could be connected between them by the Pins using SERIN / SEROUT command .
Some times one Basic Stamp is a master and the others are slaves.
Then I could connect a Basic Stamp to a Propeller by a PIN using the Propeller
like a master and one or more Basic Stamps like slaves just adding 1K resistor in each
PIN .
Is this possible ?
Thanks Mark
The propeller can do everything... Just use the 1k resistor as a current limitng (and voltage drop producing)·resitor as to not fry the propeller chip.
Go to the object exchange and look around.
Nyamekye,
Note: The diode current must be less than 500uA, but the Stamp output voltage doesn't really reach 5V, so a 1K resistor is adequate.
