Motor and HB-25 question
Hello all,
I am embarking on a project for a University research and development group and I need to know if the motor set (http://www.parallax.com/desktopmodules/catalookstore/ProductDetails.aspx?ProductID=507) can be used to the same effect without the HB-25 motor controller (http://www.parallax.com/desktopmodules/catalookstore/ProductDetails.aspx?ProductID=64). What are the advantages of using the motor controller over not using it? Do you need one HB-25 motor controller for each motor?
To give you some more insight as to what I am doing, I need to control the two motors in the above kit independently of each other based on input GPS data. The end result should point an antenna at a moving to which I am also recieving GPS coordinates.
Thank you for your time!
