parallel lcd control
I have just got an parallel lcd working following an example from http://www.weethet.nl/english/basicstamp2_lcdcontrol.php, but I don't understand why my lcd (a 16x1) doesn't print more than 8 characters? I can't figure out how to utilize the whole row of the lcd.
the code is:
the code is:
' -----[noparse][[/noparse] Constants ]-------------------------------------------------------
RS CON 4 ' Register Select (1 = char)
E CON 5 ' LCD Enable pin (1 = enabled)
' LCD control characters
ClrLCD CON $01 ' clear the LCD
CrsrHm CON $02 ' move cursor to home position
CrsrLf CON $10 ' move cursor left
CrsrRt CON $14 ' move cursor right
DispLf CON $18 ' shift displayed chars left
DispRt CON $1C ' shift displayed chars right
DDRam CON $80 ' Display Data RAM control
' -----[noparse][[/noparse] Variables ]-------------------------------------------------------
char VAR BYTE ' character sent to LCD
index VAR BYTE ' loop counter
' -----[noparse][[/noparse] EEPROM Data ]-----------------------------------------------------
Msg DATA "BASIC Stamp 2 LCD in action" ' preload message
' -----[noparse][[/noparse] Initialization ]--------------------------------------------------
Init: DIRL = %00111111 ' set pins 0-5 as outputs
OUTS = $0000 ' clear the pins
' Initialize the LCD (Hitachi HD44780 controller)
LCDinit: 'pause 500 ' Wait for LCD init
' STANDARD HITACHI 44780 4-BIT INIT
char=%00000011 ' Set 8-bit mode (1)
GOSUB LCDCMD
char=%00000011 ' Set 8-bit mode (2)
GOSUB LCDCMD
char=%00000011 ' Set 8-bit mode (3)
GOSUB LCDCMD
char=%00000010 ' Set 4-bit mode
GOSUB LCDCMD
char=%00101111 ' Set duty cycle 11xx = 5x11 matrix
GOSUB LCDCMD ' 10xx = 5x8 matric
char=%00000000 ' Display control mode
GOSUB LCDCMD
char=%00001000 ' Set display OFF, cursor OFF, blink OFF
GOSUB LCDCMD
GOSUB LCDCMD
char=%00001111 ' Set display ON, cursor ON, blink ON
GOSUB LCDCMD ' 11CB -> C=1 cursor on, B=1 blink on
char=%00000000 ' Entry control mode
GOSUB LCDCMD
char=%00000110 ' Set cursor right, no display shift
GOSUB LCDCMD ' 01IS -> I=1 cursor right, S=1 shift display
char = ClrLCD ' Clear LCD
GOSUB LCDCMD
' -----[noparse][[/noparse] Main Code ]-------------------------------------------------------
Start:
FOR index = 0 TO 39
READ Msg + index, char ' get character from EEPROM
'char=index
GOSUB LCDwr ' write it
NEXT
PAUSE 1000 ' wait 2 seconds
char = ClrLCD ' clear the LCD
GOSUB LCDCMD
PAUSE 500
GOTO Start ' do it all over
' -----[noparse][[/noparse] Subroutines ]-----------------------------------------------------
' Send command to the LCD
LCDcmd: LOW RS ' enter command mode
' Write ASCII char to LCD
LCDwr:
OUTA = char.HIGHNIB ' output high nibble
PULSOUT E, 1 ' strobe the Enable line
OUTA = char.LOWNIB ' output low nibble
PULSOUT E, 1
HIGH RS ' return to character mode
RETURN
P.S. – If you write a program that keeps printing characters it should eventually show up on the second half of the display.
Parallax Engineering
