Interfaceing Propeller to 74LS245's
Hi!· I am thinking about a Propeller project and would like to confirm what I think I learned from the hardware interfacing sticky message.
I would like to attach 5v TTL 74LS245's to a 3.3v Propeller.· Is the circuit in this thread
http://forums.parallax.com/showthread.php?p=585920
safe and reliable for long term operation?· Specifically the voltage divider network that Tracy Allen posted with the 1K series resistor and the 10K pull up resistor on the 3.3v side.· I would like to skip the 3.3 zener diode as it appears to be not necessary.
Thanks and have a nice day!
Andrew Lynch
Andrew Lynch
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I agree that the 74HCTxxx chips are more modern and in most ways better than their 74LSxxx predecessors.· HCT uses less power, less current, improved fanout, etc.· However, the 5v to 3.3v interfacing issue is my primary concern since I would like the Propeller to drive a legacy circuit and I need a way to reliably "insulate" the effects of the 5v system on the Propeller.· I am mostly interested in the 74LSxxx chips because that is what the legacy circuit uses and I would like to preserve it unmodified.
At least in my background, mixing chips of differing source voltages and levels is·not recommended·because even though it may work temporarily it can have long term stresses on the lower voltage parts which reduce their life spans and reliability.· I would like to make sure the voltage divider approach works long term and not just experimentally or under special conditions like taking special steps to make all pins inputs or outputs when not being used.· The voltage divider approach looks sound but I would like to confirm it and make sure there are no special conditions associated with it.
For the most part, 74HCTxxx and 74LSxxx are level compatible and interchangeable.· Personally, I would like to avoid the HC chips because they introduce level mismatch issues I would rather avoid especially with the legacy circuit.· Ideally there would be a 74245 like bus transceiver DIP chip that would allow 3.3v operation on one side and 5v TTL on the other.· Those devices do exist but are only SMD AFAIK.
Andrew Lynch
Post Edited (lynchaj) : 1/8/2009 6:09:31 PM GMT
Then, I should be able to build this circuit?
www.sosaraujo.com/imagenes/bus-transceiver.pdf
Thank you
Adrian Sosa Araujo.- San Luis, ARG - Time Zone (GMT -3)
El planteo de un problema es mas importante que su soluci
Saludos desde San Luis. Ya sab
