Looking at the schematics, both have female connectors with data out on pin 2, data in on pin 3, and ground on pin 5.· So, you need to make a null* cable.· This way you can comm with the SSC through the HWB programming connector [noparse][[/noparse]SEROUT 16, SERIN 16], but you won't be able to do/use DEBUG at the same time.
If you will need to DEBUG and comm with the SSC, then you will need to make an RS-232 interface and use P0-P15 as you like.
* since it has a male connector on both ends it's technically a null terminal, but proper nomenclature has gone by the wayside, in the name of expediency,·and these are called, just as their female-to-female counterparts, null modem cables.
If you look a little closer at the Lynxmotion SSC-32 Servo Board schematic (http://www.lynxmotion.com/images/data/ssc32sch.pdf), you will notice a TX, RX and Gnd connection on the other side of the RS-232 to TTL level converter. The TX, RX and Grnd connections are for a TTL level serial input and should work fine with the Homework Board without the need for any level shifting or null cabel at all.
The following link shows various connections with the Lynxmotion SSC-32 Servo Board and, among other things, the BBII which is similar in function to the Homework Board and the BOE: http://www.lynxmotion.com/images/html/build136.htm#aglance.
Just a thought.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
Post Edit -- Picture added.
Post Edited (PJ Allen) : 1/8/2009 1:22:28 AM GMT
Just a thought.
TCIII
There you have it, Dr. Evil.
