Making a continuous rotation servo not so continuous.
I'm working on adding arms for my robot and i've hit a snag.
I'm using two parallax continuous rotation servos for shoulder joints because... well... its what I have.
It's a bit pricy to pay $35+ for standard servos just for the robot's arms so I'd like to figure out a way
to use the servos I have.
My problem is the arms are impossible to control because I can't monitor the position properly.
I need the arms to be able to reach full down, forward and full up... that's it.
I've tried to puzzle out exactly how to do this without having to buy anything else.
An encoder disc would work, but that'd be quite ugly and hard to do on my setup.
I don't have a hall-effect sensor, so magnets are out.
A pot glued to the arm and suspended by some kind of shoulder plate is out because of the setup.
I've got a couple IR leds and receivers, but not enough for all three positions on both arms.
I'm toying with the idea of a shielded LED mounted on the arm and three CDS cells at the various
locations on the torso, but its a rather crude idea and it'll be ugly and use up almost all my CDS cells.
I wish there was some way to put an encoder INSIDE the servos but there doesn't seem to be enough
room in the top half (where the gears are)... is there enough room in the bottom half? (I've been too
nervous to take out all the gears).
Any suggestions will be greatly appreciated.
PG
gear section instead of the bottom...
Unfortunately, there's no pot in there and while there is a good bit of room available in the bottom section (where the motor and electronics are), there's no way to put an IR encoder or anything
of the like onto the shaft of the motor.
I considered trying to add an IR pair I carved out of an old mouse to the gear section, I figured the grease would be a problem... also the IR pair is too large.
I'm still toying with ideas to add a pot or encoder to the servo... I'd welcome any additional suggestions.
Ron
PG
At least thats what I gather from the modifying servos tutorials I've seen on the 'net... you have to clip off the stop in order to make it continuous and I don't
see a way to put the stop back.
Kelvin: That's a great site... although it doesn't help my current situation, it's really interesting and I'm sure I can use it in the future, thanks!
Sailman: I'm curious... where can you get a servo with the same power/connector as a parallax servo for half the price? (PM might be best to answer this)
PG
