Question. — Parallax Forums
Question.
PasserbyPasserby Posts: 17
edited 2009-01-09 13:57 in BASIC Stamp
' {$STAMP BS2}
' {$PBASIC 2.5}
' Project: GT60-Phone Systen
' Group members: Chia Kok Kuang 0604912F
' : Song Chan Meng 0607862J
a VAR Byte
SETUP:
INPUT 1 'Set PIN 1 to INPUT
INPUT 2 'Set PIN 2 to INPUT
INPUT 3 'Set PIN 3 to INPUT
INPUT 4 'Set PIN 4 to INPUT
BINARYCHECK:
IF IN1 = 1 AND IN2 = 0 AND IN3 = 0 AND IN4 = 0 THEN a = 1
IF IN1 = 0 AND IN2 = 1 AND IN3 = 0 AND IN4 = 0 THEN a = 2
IF IN1 = 1 AND IN2 = 1 AND IN3 = 0 AND IN4 = 0 THEN a = 3
IF IN1 = 0 AND IN2 = 0 AND IN3 = 1 AND IN4 = 0 THEN a = 4
IF IN1 = 1 AND IN2 = 0 AND IN3 = 1 AND IN4 = 0 THEN a = 5
IF IN1 = 0 AND IN2 = 1 AND IN3 = 1 AND IN4 = 0 THEN a = 6
IF IN1 = 1 AND IN2 = 1 AND IN3 = 1 AND IN4 = 0 THEN a = 7
IF IN1 = 0 AND IN2 = 0 AND IN3 = 0 AND IN4 = 1 THEN a = 8
IF IN1 = 1 AND IN2 = 0 AND IN3 = 0 AND IN4 = 1 THEN a = 9
IF IN1 = 0 AND IN2 = 0 AND IN3 = 0 AND IN4 = 0 THEN a = 0
DEBUG CR, "Binary Code sense a " a "."
PAUSE 200
GOTO BINARYCHECK
How do I display the value of 'a' in this code?
  • sylvie369sylvie369 Posts: 1,622
    edited 2009-01-07 03:42
    Try changing
    to
    DEBUG CR, "Binary Code sense a ", DEC a,"."
  • PasserbyPasserby Posts: 17
    edited 2009-01-07 03:59
    Thank you.
    edited 2009-01-07 07:17
    Hi Passerby,
    It wasn't part of the question, but you may replace,
    all with the much simpler expression...
    a = INS >> 1 & $F
    Tracy Allen
    www.emesystems.com
    edited 2009-01-09 02:38
    a = INS >> 1 & $
    What does the expression mean?
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    a VAR Byte
    SETUP:
    BINARYCHECK:
    a = INS >> 1 & $F
    PAUSE 200
    GOTO BINARYCHECK
    like this?
    EDIT 2:
    Shouldn't it be:
    a = INS >> 0 & 9
    if I want it to count starting from 0, and ends at 9?
    [noparse]:)[/noparse]
    Post Edited (Passerby) : 1/9/2009 6:34:04 AM GMT
  • agfaagfa Posts: 295
    Passerby said...
    The "INS"·reads·the inputs 0 to 14 as a word, the ">> 1" shifts the value 1 bit to the right, then the "& $F" masks·bits·0 to 3.· The shift converts the values you input from decimal 0 to 18 -to- 0 to 9. The mask ingores bits 4 to 15, by using a bitwise AND "&" with the hex value F.
    Post Edited (agfa) : 1/9/2009 4:18:26 PM GMT
