Using the DS1620 Digital Thermometer / Thermostat
Hi all, First time posting a question. I am experimenting with the DS1620 and found an interesting problem maybe you can help me with. After hooking everything up and running sample program provided by Parallax, I was satisfied with the performance until I discovered it would not calculate 68,70,72,74,& 77 degrees F. There may be more numbers but I gave up running it through the paces. Is this an issue with the conversion from C to F or is it a problem enhanced by Basis Stamps not liking fractions? Any help is appreciated.
Mike2545
Mike2545
Post the code and schematic you are using. After the we have a look, it will make everything clearer. I am having no issues with several 1620's I have.
Tex
The more I look for common sense in the world...
the more·I·find how un-common it is.
The DS1620 can do better. as it does return the temperature to a resolution of about 0.5 degree Maybe the demo program rops the fraction before it converts to Fahrenheit.
Tracy Allen
www.emesystems.com
Here is a copy of the program I am using.
What has been suggested as far as the conversion from C to F is indeed what is happening.· Not to add insult to injury, the code that you are using only uses a resolution of 1 Deg C instead of 0.5 Deg C.· This translates to 1.8 Deg F resolution
Look at the following link on page 161 for a slightly modified version of code that will display the temperature in 0.5 Deg C resolution. (0.9 Deg F)
http://www.parallax.com/Portals/0/Downloads/docs/books/sw/Web-SW-v2.1.pdf
...There is yet another way to get an even higher resolution out of the DS1620.· Starting on page 168 of the same article, the maximum resolution is 0.0625 Deg C (0.1125 Deg F)
Since the·article·above was written,·there is no longer a need to read the Slope (or number of Counts per Deg C).· Read here to find out why... http://forums.parallax.com/showthread.php?p=608042
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 1/7/2009 4:58:20 PM GMT
Thanks for the support. I'll re-work my program with this new information.
Mike2545
