Inverted pendulum robot: Complementary filters
Hello,
I'm studing Robotics at The University of Plymouth and I'm currently in my final year. My final year project is a robot that balances itself on a ball and uses the Propeller Chip as its main processor. These are two pictures of the base of the robot, not yet finished:
http://img508.imageshack.us/my.php?image=1002654smallwp0.jpg
http://img444.imageshack.us/my.php?image=1002655smallxx2.jpg
The robot uses stepper motors as main actuators, with encoders for stall detection, one MCP3208 12bit ADC and two IMU 2Dof boards (one for X and one for Y). I have modified an assembly program called "MCP3208_fast.spin" to sample all channels at 1.5Khz each and loop forever without never returning from the assembly code, it writes the values to the main memory directly. I'm now trying to figure out a way to fuse the accelerometers and the gyroscopes to get a true angle posivion and angular velocity for each axis. I bet you are gonna say "Kalman Filter!" but no, I would like to use a simple complementary filter aproach. The kalman filter source codes I've found so far available for download either use too many cogs (and still require further modification for my aplication) or use an FPU which I don't have. I know that the complementary filter approach works fine because I've seen other projects that tried it out and succeded. I would like to ask if anyone here knows how to code a low/high pass filter in propeller assembly. That is all I need to know in order to move on to the main control phase of my project. Any comments about my projects are welcome.
Alex
Alex
Edit: Nevermind. They need a link:
Photo 1
Photo 2
In a nut shell replace dx/dt with (X{n} - X{n-1})/T where T is the time between samples, X{n} is the current value of X and X{n-1} is the last sampled value of X. (do the same for "y" or any other variable) Now solve for the most recent value of the output variable. (usually Y{n} or Y{n+1})
Marty
P.S. the structure you end up with is also know as an IIR filter.
Lunch cures all problems! have you had lunch?
Post Edited (Lawson) : 1/7/2009 4:47:28 AM GMT
Somewhere I have an algorithm in C that gives low pass and high pass outputs from three stages of integration each with feed back to the input. I don't have much of a clue about digital filtering I just wrote the algorithm as a simulation of an op amp circuit I found. A musically inclined friend of mine has been using it as an active crossover for his loudspeaker set up on a PC for years now and loves it. Not sure if it would count as a complimentary filter though. I can try to dig it out if you like.
Actually I'd love to get that algorithm working on a Prop as a stand alone digital crossover but that's another story...
a) How to define, mathematically, algorithmically what the filter should be ?. How it works in general.
b) I have my filter algorithm, how can I implement it in Prop assembler ?
Perhaps you could define for us exactly what your inputs and expected outputs are.
Excuse my ignorance but if we had a high pass filter and subtracted its output from the input wouldn't the result be a low pass filter. The sums sure always add to one so it's complementary, right. Or is there more to a complementary filter ?
I'm sure floating point is not required. There are plenty of 32 bit integer multiply/divide routines knocking around here somewhere. I've done Mandlebrot sets in integer arithmetic in the past.
www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1824&appnote=en011082
I can also generate filter code in Micro C (for a dsPIC) if you want to try and convert it to prop Spin or Asm.
Aka: CosmicBob
www.mtoussaint.de/tobb/index.html
It's hard to find this stuff as so many confuse compliment and complement (Myself included).
Alex
