Clocking the Prop off of FTDI's CBUS? — Parallax Forums
RaymanRayman Posts: 16,379
edited 2009-01-07 00:42 in Propeller 1
I just noticed that you can configure one of the FTDI FT232R pins to give a 6 MHz clock...· I'm thinking of using that as a clock input to the Prop.· Anybody tried this before?
    edited 2009-01-06 20:10
    I think it's been done. But the FT232R uses an internal oscillator and not a crystal. So you're not likely to get an accurate enough frequency to do things like NTSC video, especially if you want color.
  • TubularTubular Posts: 4,774
    edited 2009-01-06 20:11
    Yep just about to try it on the next revision of the patchbox. I'm not sure it will be good enough for video generation but am going to give it a go. Just in case it doesn't work out plan B is ye olde standard crystal.
    Now what I really would like to see, is FTDI incorporate an i2c eeprom emulator, so we could put a small SD card boot loader in its 1k of EEPROM.
    I'll know in a couple of weeks how it goes and let you know
    tubular
    897 x 437 - 41K
    edited 2009-01-06 20:23
    I found where this was done: the DLP-Prop. Here is a thread that discusses the difficulties in getting good video output from it, due to inaccuracies/instabilities in the 6MHz clock.
  • parts-man73parts-man73 Posts: 830
    edited 2009-01-06 20:49
    Also, if not plugged into USB, you loose the clock, if the FTDI chip is USB powered. You have the option of powering the FTDI chip from the USB, or it can be connected to the same power supply as the Propeller.
    Brian
    uController.com - home of SpinStudio - the modular Development system for the Propeller
    PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
    SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
  • RaymanRayman Posts: 16,379
    edited 2009-01-06 20:57
    Thanks! The DLP-Prop shows that it is possible to work...
  • ColeyColey Posts: 1,130
    edited 2009-01-06 23:46
    Ray,
    I have a dlp-prop, it is pants compared to a Prop and crystal setup.
    you only get ~6MHz once it has enumerated And it is not possible to get a stable tv signal with it.
    It was the first Propeller based product I bought and it almost put me off completely it was that unstable
    I ended up disabling the clock outut and soldering on a small crystal, was tricky and took some effort but the difference was well worth it.
    I suppose if your app isn't timing critical like tv is it will be ok though smile.gif
    Coley
    PropGFX - The home of the Hybrid Development System and PropGFX Lite
    Oh, I didn't know you didn't get the clock until enumeration... That's a non-starter then... I want to be able to use the mini-usb cable to supply wall power 5V...
