POV Propeller clock
Hi Guys,
I need some feedback from you gurus out there.
One of the projects I have always wanted to build is a propeller clock, or one of its variants. ...· The type that uses spinning leds and relies on·persistance of vision, POV, to produce an image that appears to be floating in air. Here's a link if you aren't familliar with what I mean:· http://www.youtube.com/watch?v=no2_M_b059g&feature=related
I'm used to working with the different stamp versions, but haven't yet taken the propeller chip plunge. (I know, I should have gotten the developement board while it was on special) ....···· Anyway, does this look like a project that could be done with a stamp, or do I need to take the jump to the propeller if I want to build one of these? ....· Or on the other hand, is it better to keep it as simple as possible and just use a pic and buy a pic programmer and learn to program that?
Thanks in advance for your feedback,
Darlene
Darlene
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I think the hardest part is "How do you get power to the spinning board ?" and "How do you sync the spinning board so the image is stable ?".
Bean.
·The next time you need a hero don't look up in the sky...Look in the mirror.
· An infrared led fixed to the base and a sensor on the underside of the spinning blade (think of an optically triggered ignition system) can be made that's highly accurate.
··I was hoping to make this a Parallax based project, that's why I haven't gone and just cloned what's already been done with pics.
Darlene
Post Edited (Geekgirl) : 1/6/2009 4:15:08 PM GMT
