Fast SPI object — Parallax Forums
Fast SPI object
4Alex4Alex Posts: 119
edited 2009-01-05 18:40 in Propeller 1
Hi all,
I am currently using the SPI Object (Synchronous Serial) adapted from the BS2 object (written in spin). The clock rate is stated to be ~16Kbps. I am interfacing a device that can be accessed at up to 2Mbps. Does anyone knows if there is a faster SPI object available?
Many thanks for your assistance.
Cheers,
Alex
  • LeonLeon Posts: 7,620
    edited 2009-01-05 16:40
    There's an SPI engine coded in assembler in the Obex. I think that is where I found it, at any rate.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    edited 2009-01-05 16:45
    The SPI engine is described in the "Assembly Code Examples for the Beginner" thread here:
    http://forums.parallax.com/showthread.php?p=601870
  • 4Alex4Alex Posts: 119
    @Mike:
    Thank you for the reply. I've downloaded the SPI code written in asm by Beau.
    Cheers,
    Alex
