Newbie Questions
Hey all, just wondering if anyone out there can explain to me (or know of a good link) how I can plug my BS2 project into a wall without having to buy a carrier board?· I want to mount my BS2 to a thru-hole pcb (like the kind at radio shack) for a project and would like to still use the same wall plug that I've been using on my BOE.· Any help?
Also, does anyone know of a good place to buy insulated wire that is OOBER thin?· I've been trying to find some #38 awg wire for my LED project and have had absolutely no luck.
Thanks!
Thanks!
For very thin wire, try wire wrap wire.
Its best to follow SRLM's suggestion and use an external 5 volt voltage regulator. You may need a capactior or two in addition to the regulator... its best to read the datasheet for
whichever regulator you buy and follow its instructions.
You'll also need a barrel-jack to connect the wallwart... you can find these at most online stores and radioshack.
As far as thin wire... try opening Cat5 ethernet cable. Inside are fairly small twisted pair wires. I'm not sure on their gauge.
