Choosing the Right Power Supply
I'm considering buying a power supply for personal use, and I was wondering what sort of recommendations anybody might have. I've found that I can have one new piece of test equipment, and the power supply has beat out a soldering iron, oscilloscope, function generator, and desoldering iron. So, for my supply, I would like something that works with about 3 to 16 volts, up to about ~20 amps (for large motors). The smoother the output (lower ripple?) the better. As for cost, something less than about $350 would be good, especially if I can use it for years to come. Any suggestions? Perhaps a respected manufacturer or two?
Rick
Here is something that·I have done before
LM338k will handle 5 amps
If you can sill find these
LM396 or LM196 can handle 10 amp
I have set·LM338k···up for 5 amp current mode and they work very well but you have to use a heavy Heat Sink
with them
I did a quick search on Google for a 20 Regulator and did not find any
·Now you can use· bypass transistor whit a LM338k and get 20 amps output
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 1/6/2009 2:39:20 AM GMT
I think I'll probably stay away from making my own, for several reasons:
1. The electricity involved can kill if I'm not careful (120 VAC)
2. The power supply would have to be either a) constant voltage or b) variable voltage with probably poor regulation/temperature compensation
3. It won't have a nice display that concurrently displays both voltage and amps
I'm not really an electrical engineer (more computer science), so the power supply is to help me get the hardware working so I can go code. I don't want to worry about having to troubleshoot both my power supply and my robots. However, I'll keep the suggestions in mind if I need to construct a permanent power supply for some project.
Anyway, here is a power supply that I found and think will work well. Any comments?
Edit: Hmmm. Looked again at the listing, and found it was for 110 volt AC, not the 120 v AC that I need here in the US (I don't live in Brazil or Belize), so it won't work. Back to the search engine.
Post Edited (SRLM) : 1/6/2009 4:19:58 AM GMT
Gadget Gangster - Share your Electronic Projects - Sign up as a Designer and get a free 4-pack of Project Boards!
B&K Precision 1696
