Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
seperate power supply connection — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Propeller 1
science_geek
247
2009-01-04 18:24
edited 2009-01-05 12:22
in
Propeller 1
i was wondering if it was possible to set up a propellor for some sort of communication without having a common ground, like a servo or esc from a hobby rc plane
StefanL38
2,292
2009-01-04 19:18
edited 2009-01-04 19:18
Hello,
whenever the connection is electrical there have to be a common ground otherwise
the voltagelevels can "flow around"
Your thread title speaks of powersupplying. There it is the same. If you don't connect grounds
to each other you have no reliable function.
If the devices have to be separated electrically use optocouplers or relays
best regards
Stefan
Post Edited (StefanL38) : 1/4/2009 7:41:47 PM GMT
Adrian Schneider
92
2009-01-05 12:22
use an optical connection, e.g. an optoisolator.
Sign In
Register
to comment.
best regards
Stefan
