communication help — Parallax Forums
communication help
seadog13seadog13 Posts: 9
edited 2009-01-08 03:46 in Propeller 1
hey all, I'm stuck and getting frustrated, I am trying to get communication between two propellers. trying to go wired, as simple as possible.
Using full duplex serial obj, I believe I am receiving an ascii character from a decimal number being transmitted, although when converted to decimal it's no where close to what i was sending. I have read over all the posts in the forums, it seems like I am doing everything correct, I don't know where I am going wrong. As far as circuit side, I have them running into two different pins, ie not tx pin = 3 on both props, and a common ground between the two propellers. Below is a copy of the code that i have.
any help is greatly appreciated.
CON
· _CLKMODE = XTAL1 + PLL16X
· _XINFREQ = 5_000_000
OBJ
serial : "FullDuplexSerial"
debug· : "FullDuplexSerial"
fs··· :···· "FloatString"
var
· long rx
pub main
··· debug.start(31,30,0100,19200)
··· serial.start(3, 26, 0000, 9600)
···························· 'rx pin, txpin, baud
··· repeat
····· serial.dec(1)······················· '·transmit side
····· debug.str(string("sent"))
····· debug.tx(13)
··· ·waitcnt(clkfreq + cnt)··········· ' receive side
····· rx := serial.rx
····· 'debug.tx(13)
····· debug.tx(rx)
I·am running the PE propeller and I·changed the computer tx, rx pins from 31,30 to something else, and it wouldn't·work, is there something fundamentally that I am missing?
····· debug.tx(13)
Post Edited (seadog13) : 1/4/2009 3:24:04 AM GMT
  • grasshoppergrasshopper Posts: 438
    edited 2009-01-04 03:17
    I dont not look like you have the receive code displayed. Perhaps your sending it ok but I see no receive code for the other prop to run. If you still need help P.M. me otherwise I am sure others will post something.
    edited 2009-01-04 03:19
    For starters what is the decimal value 100 doing as the mode value in debug.start? Even if you made it binary it still wouldn't be right, this value for most purposes is simply zero.
    Anyway, for debug purposes it is far better to represent the incoming debug stream as hex characters.
    debug.tx(" ")
    debug.hex(rx,2)
    *Peter*
  • seadog13seadog13 Posts: 9
    edited 2009-01-04 03:36
    the debug.start is for my parallax serial terminal program. The serial.start is what I am trying to send. When i would receive the ascii i would get 254, when i received the hex, i got 254 as well. so that didn't really do anything. I also tried to transmit the data in hex, and got the same response.
    edited 2009-01-04 03:56
    You only want to see the hex representation of the binary character that is received, don't transmit it in hex. The important thing is to get rid of the 0100 in your debug mode setting.
    should be
    debug.start(31,30,0,19200)
    *Peter*
    edited 2009-01-04 04:00
    Prop Tools under Development or Completed (Index)
    http://forums.parallax.com/showthread.php?p=753439
    cruising][noparse][[/noparse]url=http://www.bluemagic.biz]cruising[noparse][[/noparse]/url][/url]
    This is a [noparse][[/noparse]b]bold[noparse][[/noparse]/b] test.
    edited 2009-01-04 04:48
    Try this
    prop A
    CON
    OBJ
    pub main
        ser.start(3, 26, 0, 9600)
        repeat
            serl.str(string("sent"))
    prop B
    CON
    OBJ
      ser : "FullDuplexSerial"
    var
      Byte Rxdata [noparse][[/noparse] 6 ]
    pub main
        ser.start(31, 30, 0, 9600)
        repeat
            IF (ser.rxcheck == "s")
            getcom
    Pub Getcom | stringCount
      StringCount~
      Repeat UNTIL (RxData[noparse][[/noparse]StringCount] := SER.rx ) == "t"
              StringCount ++
       IF (rxData[noparse][[/noparse] 0 ] == "e")&(rxData[noparse][[/noparse] 1 ] == "n") '  fixed
            {{light led}}
    Post Edited (grasshopper) : 1/8/2009 3:50:20 AM GMT
    edited 2009-01-08 03:29
    Hey all, grasshoper thanks for the help. We were able to send data across and rx it, but still had afew problems.
    We wouldn't always receive what was being sent, the string would get mixed up, but then after a couple of transmissions, or even the next transmission, it would correct itself. I was thinking of some sort of forward error correction.
    We also noticed that it got better when we played with the timing. We built an array for each bit to write to, and then displayed them individual. was wondering if there was any tricks of the trade on getting the rx side correct. Below is a copy of the rx code, the tx code is what grasshoper posted above. We are sending !sentX, using the ! as the check, and the X as the terminate.
    CON
    OBJ
    debug : "FullDuplexSerial"
    VAR
    byte rxdata[noparse][[/noparse]7]
    pub main |i,j
    ser.start(12, 11, 0, 19200)
    repeat j from 0 to 5
    rxData[noparse][[/noparse]j] := j
    rxData[noparse][[/noparse]6] := 0
    repeat
    waitcnt(500_000_000/5 + cnt)
    'waitcnt(clkfreq+cnt)
    'debug.str(string("check"))
    IF (ser.rxcheck == "!")
    getcom
    else
    debug.str(string("Noooo"))
    debug.tx(13)
    repeat i from 0 to 3
    debug.dec(rxdata)
    debug.tx(13)
    Pub Getcom | stringCount,i
    StringCount~
    debug.str(string("ok!!!!!!!"))
    debug.tx(13)
    Repeat UNTIL (RxData[noparse][[/noparse]StringCount] := SER.rx ) == "X"
    StringCount ++
    IF (rxData[noparse][[/noparse]0] == "s")&(rxData == "X")
    {{light led}}
    debug.str(string("yay"))
    debug.tx(13)
    repeat i from 0 to 4
    debug.dec(rxdata)
    debug.tx(13)
    'waitcnt(clkfreq*2+cnt)
    'debug.tx(16)
    Yea the code is not right
    IF (rxData[noparse][[/noparse] 0 ] == "s")&(rxData == "X")
    This is wrong or at least looks wrong. Try this
    IF (rxData[noparse][[/noparse] 0 ] == "s")&(rxData[noparse][[/noparse] 1 ] == "X")
    Also in other parts of the code the variables are incorrect rxData == "X". rxdata is an array and each byte fills that array. So the letter "X" is one byte, or a slice of the rxdata[noparse][[/noparse] 0 ] array. So if the other propeller is looking in rxdata[noparse][[/noparse] 1 ] for an "X" and you give it just rxdata its not going to be consistent.
    edited I posted the code wrong the other day, well the website hates the [noparse][[/noparse] ] so I had to do a [noparse][[/noparse] 1 ] for example. Sorry!
    Post Edited (grasshopper) : 1/8/2009 3:51:37 AM GMT
