How many power supplies for robot?
Hi All,
I've been building a little sumo bot, and was kind of curious if anyone had any tips or rules of thumb for power sources. I've got 4 motors running at 12v, 2 servos, a few very low power sensors(ping, sharp, qti), and the propeller microcontroller. Currently I have a 12v rechargeable battery pack for the motor controller and motors, a 6v AA battery pack for the 2 servos, and a 9v battery for the propeller and sensors (regulated to 3.3v for the prop and 5v for everything else). I was hoping to possibly reduce the amount of separate power supplies, but wanted to see if anyone has had any experience with this.
The 2 servos are on their own supply because I was experiencing some odd behavior from the microcontroller when the servos were strained at all (even just touching them while they were being commanded to stay in one place). I observed over 1/2 a volt drop in their supply when strained and figured the odd behavior was due to a brown-out like condition.
Would a large enough cap allow me to run these 2 servos from the regulated 5v instead of directly powered from the 6v source? Any rules of thumb on how to figure out the size capacitor needed to smooth the power demand?
Any recommendations on consolidating the supplies? Dos or don'ts? Should I be worried about the amount of current the single 12v source could supply if I chose to consolidate to this source only?
My equipment:
spin studio mainboard with prop
12v ni-mh 1600mah rechargeable battery pack http://www.lynxmotion.com/Product.aspx?productID=64&CategoryID=48
2 ping sensors, 2 sharp ir sensors -> connect through an adc chip, 2 qti sensors
4 12v motors http://www.lynxmotion.com/Product.aspx?productID=94&CategoryID=11
2 hitec standard servos
Thanks for the help,
Will
My equipment:
Will
equation aswell
