Wall wart resistance
I have a small wall wart rated at 2.7V and 240mA.
I measured the voltage output·with my DMM "Amprobe 34XR-A" and got 2.71V.
Then I measured the resistance "unpluged" and got 218 Kohms.
Using the ohms law calculator here: http://www.onlineconversion.com/ohms_law.htm
I entered the rated volts·and milliamps and got 0.0112 Kohms
But when I entered the actual volt and·resistance values from the DMM I get: 0.0124 milliamps which is no where near the rated 240 milliamps. Whats going on here?
There are many different output current ratings. Which do you want?
1) Maximum current output before shutdown or damage occurs (short circuit current)
2) Maximum current at rated voltage (2.7V)
3) Maximum current at some other voltage.
In the case of #2 or #3, you have to provide a load resistance and decrease that while measuring the voltage across the load (and the current through it).
In the case of #1, you have to do the same thing while decreasing the load resistance towards zero and watch for overheating or a voltage/current curve that suggests that the supply is shutting itself down to prevent internal damage from overcurrent or overheating.
- Stephen
If you want to check that the power supply can still deliver 2.7V at 240ma then you should load it with the equivalent resistance and then measure the voltage. R=V/I -> 2.7/0.240 = 11.25 ohms. The resistor needs to be able to handle 0.65W so I would use two 22R 1/2W resistors in parallel to approximate your load.
But why are you trying to test your wall wart?
*Peter*
Post Edited By Moderator (Chris Savage (Parallax)) : 1/5/2009 4:06:24 PM GMT
