RFID activates a solenoid
I’ve got an idea that I would like to use RFID and I need some help building the circuit.· I am a beginner at programming circuits, but I can build them ok.· I need to make an RFID circuit that activates a small solenoid (12V) when a specific RFID tag hits the reader.· Also I would like a way to quickly program the circuit to any, one RFID tag.· Any ideas would be great as I am pretty inexperienced.·· Thanks for the help!!
Have you looked at the Nuts and Volts Column (#120) on using the RFID reader?
Click the Resources tab on the main Parallax webpage and you'll see the Nuts and Volts Columns index.
Both of these pretty much show how to do what you want.
Post Edited (Mike Green) : 1/2/2009 6:03:25 AM GMT
Also, please don't duplicate post.
Your duplicate post in the BASIC Stamp forum has been removed.
Parallax Engineering
Take a look at this post this will help you do this part of what you want to do
When a specific RFID tag hits the reader.·
http://forums.parallax.com/showthread.php?p=586138
Also look at this post as well
http://forums.parallax.com/showthread.php?p=595469
This can be done by how you write your routine for that one card or for more than one card
you could have each card turn a different solenoid if you wanted to that way
I hope this helps
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 1/5/2009 1:39:35 AM GMT
