DAC question
I am working on a project currently and have very little space to work with. My project is made to control the speed of my model rocket, and in order to do that I decided to either find a sutiable digital velocity sensor (which I'm having a lot of difficulties with
) which would turn a servo or a propeller that spins a metal gear and then use·a hall affect sensor than use the DAC to change the analog signal into a digital signal. The only problem however is that I do not know whether the DAC will be able to work the servo!!! PLZ HELP
- Stephen
