What is it? — Parallax Forums
What is it?
sobaman14sobaman14 Posts: 24
edited 2009-01-03 04:33 in Robotics
I know this may be a stupid question, but what is the small black breadboard between the Stamp bs2 and the main breadboard?
Here is a picture:
1024 x 768 - 159K
  • John AbshierJohn Abshier Posts: 1,116
    edited 2008-12-31 21:05
    It is the AppMod connector. Parallax sells a few boards that plug into it. Of course you can use the connections if they are more convient than the female header by the breadboard.
    John Abshier
  • SRLMSRLM Posts: 5,045
    edited 2008-12-31 22:04
    It has all the IO pins available, along with regulated 5v and ground. You can use it to connect two BS2s together by simply plugging in a servo extension cable on the part with ground and an IO pin or two.
  • sobaman14sobaman14 Posts: 24
    edited 2008-12-31 22:58
    So that's what it is!! Thanks!
  • WhitWhit Posts: 4,194
    edited 2009-01-01 01:07
    This very useful document tells it all...
    http://www.parallax.com/Portals/0/Downloads/docs/prod/boards/28850-BOE-USB-v1.4.pdf
    Whit+
  • boe-crazyboe-crazy Posts: 53
    It is ussed mainly for attaching the bluetooth modgule
    To make something work one must build, test, and verify bfore proceding.· -- myself
