using a basic stamp to controll a rc helicopter
so where should i start because i don't have a clue. i know i will need to run two motors one for the tail and one for the center mass of the copter. and i think i want to use ir and gps with this unit. what do you all think and where should i start ?
A RC helicopter, or plane, is a REALLY complicated project for your first. The chances of breaking expensive hardware and maybe even injuring yourself are just too high. If you really want to make it happen, download "What's a microcontroller" and work through the projects. Then, get good at flying. Then you can start making the helicopter of your dreams.
Also, you would never want to use IR to control a copter or plane. It is line of sight only, short range and sunlight interferes with it too easily. You will need to use RF for sure.
I'm NOT trying to discourage you. It's a great project and one that has been on my list for quite a while. You just need to take the time to learn what you need to know to make it actually work, instead of just wrecking hardware.
Just my .02. [noparse]:)[/noparse]
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
- Stephen
It's still a good idea though and definitely one you should keep in sight as an eventual goal. Remember, it's not the destination that matters, it's the trip along the way that counts, so have fun learning and experimenting!
Yep! The DARPA Urban Challenge, about a year ago in November. I had the good fortune to be able to attend and talk with various teams. It was fascinating, even though I didn't understand most of it. My favorite vehicle (Cornel's black SUV) had the entire rear of the vehicle as a rack of computers to process all the data. It's certainly more than the hobby level, but the principles are often simple. I liked the Standford idea: they had two sensors (a scanning laser and a camera) and they scanned the road, figured where it was safe to drive, and used the colors of the road at that area to extrapolate from the camera images. A fairly simple idea, but lots of processing power.
Anyway, the cars navigated about 60 miles of Urban terrain without crashing into other cars or breaking traffic laws. Pretty neat stuff.
· http://www.youtube.com/watch?v=DRQzaKFVjZk
Post Edited (Mikerocontroller) : 1/2/2009 6:48:01 AM GMT
I can get it to hover and fly somewhat by controlling· the levers· outputs basiclly they are pots with some adc,s and while it does work its pretty cool I have no feedback control at all, so it works like this I run the code it asks questions like how high and you can enter a value or how fast and again enter a value but the problem is since there is no feedback control it will hit the cieling or wall I will be happy to post the schematic and code but it would be awesome if we could figure out how to get feedback back from the helicopter for real control I dont think this on "heli" has any kind of feedback IR or anything built into it has pretty good lift power so maybe we could come up with something
If A Helicopter is what You want to control, Then a helicopter should be Your test bed. Use some weights to hold down the Helicopter while Your testing the code.Then remove some weight from the helicopter to allow some movement."A tie down strap with about 2 feet of slack, would do for a hover test."
The $stamp will surprise You if You use rite. And this depends a lot on the remote control set up that the helicopter uses
_____________$WMc%____________
The Truth is out there·········································· E=$WMc%2
it is on man I sent you a PM so write me back man and I will so work with you on this.
