New user with Boe-Bot having trouble...
Hi!
I am a new user, and I am having trouble with the Boe-Bot I received as a gift for Christmas. When I first tried out the IR emitters, one of them didn't work. So I went to RadioShack and bought an Infrared Emitter and Detector, but I only used the emitter, which has:
Reverse Voltage: 5V
Continuous Forward Current: 150mA
Forward Voltage: 1.3V typ., 1.7V max.
Radiant Power Output: 13 - 15mW
Wavelength at Peak Emission: 950nm
And it works great, except now the other emitter gets really hot when I run a program called Roaming With IR Emitters.
Also, occasionally the computer will say 'No usable Serial Ports Found,' even when the Boe-Bot is connected and turned on. Am I wiring it wrong? If so, I am adding some pictures of it's breadboard.
Does anyone know what I am doing wrong? Please help me!!!!
Thank you!
Post Edited (sobaman14) : 12/31/2008 7:42:50 PM GMT
Reverse Voltage: 5V
Thank you!
Post Edited (Mikerocontroller) : 12/31/2008 7:46:30 AM GMT
Thanks!
Thanks for your suggestions!
