Error when copying the program to the scribbler
Hello,
My son wants to make a program with the scribbler GUI. When he wants to copy the program to the scribbler the following messagebox appears:
Title: Stampw.exe - No Disk
Subject: There is no disk in the drive. Please insert a disk into drive Device\Harddisk1\DR2.
|Cancel| |Try Again| |Continue|
When he press a couple of times on Continue the file is copied to the Scribbler
I figured out that Device\Harddisk1\DR2 is my external USB harddisk. When I put this one in the USB port and press the copy button in the GUI there is no error and the read led on the
The read led goes on USB harddisk will flash so there is a read process.
I uninstalled the USB harddisk driver but nothing helps.
Why is the GUI and STAMPW.EXE searching on the USB harddisk? How can I fixed it?
Mark
Mark
Thanks for your reply. I did this but no success http://forums.parallax.com/forums/posticons/icon7.gif
Mark
I have attached 2 printscreens. It is 2.4.2. I use the Dutch Windows XP version. Maybe this is the problem?
Mark
